I plan to eventually pull my full dash apart to fix a few things that have been getting on my nerves. Since it's a pretty big task and I don't want to do it more than once, I just want to double check if there's anything I might be missing that I should look at while I'm there. It's going to be a decent chunk of money but I'm hoping it pays off in lasting comfort for the next 150k miles.
Here's what I'm thinking -
- All 4 blend doors, or at least the 2-3 that can't be reached with the dash in place (currently having interment issues with passenger side sticking, after I fixed driver side. Plus obnoxious hunting noises)
-Fan motor - on fan speed 1 I get a subtle but obnoxious chirping sound
-Dynamat underside of dash pad - I'm getting a rattle above the gauge cluster that is subtle but again, gets on my nerves
That's it for things actually wrong right now, but in addition to that I am considering replacing the heater core now as preventative maintenance while I'm there. I'm also considering dynamatting the backside of the firewall. Eventually I'd like to get the rest of the cab, but again, trying to only pull the dash once.
So, are there any components back there I'm forgetting about that might be worth replacing when I'm there? Anything on the column? Anything else HVAC related?
Also, I know dynamat is pretty dang adhesive, but has anyone ever tried sticking it on the dash plastic? For my dash rattles, I'm hoping that if the extra weight of the material doesn't stop the rattle itself, then at least the sound will be deadened.
