My vote goes to turning this into kurts "1000 hp stock bottom end motor" ......
We all know you like the spray, Jeff.... see what she can do :rofl:
Where does the 2nd tank go, where in ohio are you, and any pics of the tank setup?
You are then restricted to three converter to flex plate bolts and you can check your front ujoints inside the console. Spelling will not be graded. We figure if you can spell, you can read and you would have read something about checking your front ujoint in your console is not a good thing.
Between the frame rails behind the axle. It's 23 gallon/ I think the transfer pump is on top of it that pushes fuel to the front tank.
This was a factory cab/chassis? Does that mean it has a 34" wide frame?
I put a new water on the truck and this thing runs alful good. It runs and drive like it has 50k. I might have to rethink this and have a new shop truck. Jeff
