Problems only in cold weather??
Dragonsfireloki
Nov 6, 2011
175
North Dakota
As soon as the temperature gets below freezing, sometimes when the truck shifts, it's like it pops into neutral and as long as I just let go of the throttle and press again it catches. Sometimes I will lose reverse and the indicator light just flashes. Happens in drive on occasion and the truck is dead in the water until I clear the codes then it's fine again for a while. Transmission was built about four years ago about 60k miles ago. A stage V PPE kit was put in. Am I looking at a total rebuild or the NBSU switch problem??
DewDewMax
Drive fast, take chances
Jul 9, 2014
105
Sudbury Ontario
I had a issue when it got cold out, when the fluid was cold, it would limp itself, can't remeber the code and chased it for a while eventually got fed up and pulled the valve body apart and it was a cracked c shift solenoid. Like Robby said, a code will help more.
