So I fixed the lopey idle. One of the pins was pushed out of the fuel rail pressure sensor connector. It idles like a dream. I can rev it up and it’s smooth. But when I try to drive it I can go maybe half a mile and it’s like something comes loose. Starts pouring dark gray smoke and knocking. I can shut it off and crank it right back, no smoke and runs fine. I can recreate this at will. If I baby it it goes longer, driving normal not so far.
take it back as is, point out the fails and use that as fuel to get your money back. DONT have them work on it. if they wont refund you, video all the issues to file to the CC company. cover your ass here before you go throwing money at this trying to fix their f**k up.
as for the smoke, hard to say unless you have a way to monitor pulse width, commanded rail/desired rail, timing, map sensor, boost, etc. its most likely the junk injectors they put in there. i wouldnt throw a dime at anything else on that truck till i put known good injectors in.
