so after changing drain lines to a little simpler setup my truck is still leaking oil... the flange was torqued to GM spec 15 ft lbs, and it is not leaking from there. So looks like the rear main seal. How much of a PITA is it to change?
Damn that blows.
I wish my luck was only that bad
Cheer up nick...... :hug:
Make sure that's it before you start tearing it apart. Only this worse then fixing a problem is fixing something that didn't need fixed.
hahaha I love how some people consider a little oil leak "unlucky"
If my truck even moves under its own power, I consider myself "super lucky"
Is it leaking from inside the bell housing?
Rear main leaks on our engines are fairly rare.
Turbo oil leaks are REALLY common.
