Hello, I have a 2003 LB7 with a PPE Stage 5 rebuild with a 1057 converter. Rebuilt trans done way back in August - wasn't having problems until about a month ago. Under light acceleration, I know the trans will shift from 4th into 5th at around 68-70 km/h. NOW , With light throttle pressure the trans will hang 4th until I either step on it to say 1/4 - 1/2 throttle then it will shift into 5th OR if I continue to lightly throttle through, it hangs 4th then shift into 4 with the converter locked and around 90-100km/h then into 5th with converter lock. Truck is not in tow haul mode!
Before, normal operation was light throttle 4-5 at 68-70 km/h then at 90km/h 5th with converter lock would come on.....something is going on....
I've checked fluid level it is fine, I'm assuming this is a software / programming problem more than anything????
