Has anyone had an issue installing the injectors in the new style cupless heads from ppe?
Had to pretty forcefully push the injector down and it doesn't sit flush with the head. Seems the gap is about the width of the copper washer.
Not sure if I'm supposed to use the washers with these newer style heads, I should use a socket and beat it down further with a rubber mallet, or what to do at this point.
I installed a 2nd injector without the oring to check the fit and without the washer it sits flush, with the washer I have the same gap as the first I installed.
Also tried to torque the hold down to see if that sucks it down flush and at 55 ft lbs (torque spec for socal hold down studs) there's still a gap.
Waiting for ppe to open again on Tuesday to call the manufacturer but just seeing if anyone else may have had this issue before.
Any advice would greatly be appreciated.
Thanks
Thanks
