PPE Boost Controller
smarquis
Triple Turbo LBZ
Jul 15, 2010
188
Las Vegas, Nevada.
Are these worth having without the stock turbo? Got a cheetah 68 on the way, and don't know if I should just have this removed. Helped out quite a bit when I first bought it. Thanks.
smarquis
Triple Turbo LBZ
Jul 15, 2010
188
Las Vegas, Nevada.
To be honest I don't know, but I think so. I have had it on for about 4 years and you can't really turn it off unlessyou unplug it. And, although this device helped me a lot, my most recent test only showed @ 4 lbs. Difference with it dialed all the way up and down (note turbo was going bad, but I never saw a huge difference from the dial.). Overall it helped a lot though.
maddogg101920
I break stuff
Mar 2, 2007
733
CECIL COUNTY, MD
when i had one on my truck it would run upto 42 psi turned all the way up and with it off would hit 32 psi which is what the tune was set too, so id say when there turned down there off.
smarquis
Triple Turbo LBZ
Jul 15, 2010
188
Las Vegas, Nevada.
Most I ever got from mine was abou 35-37 running the highest tune on me PPE Xcelerator. Still was quite a bit more boost than without the controller.
DetailsUnlimited
1,264
Benton, Ar
Called PPE today and the guy said the dail is a vein position reason they say only a quarter turn(give or take a little). The on which ever way you have it allows boost through out the rpm until maxed out. "depends on turbo". And the off which he called a delay allows boost to come on after 18psi which the switch was set to allow.
This is what I understood.
smarquis
Triple Turbo LBZ
Jul 15, 2010
188
Las Vegas, Nevada.
Just in case anyone else with a similar situation finds this thread, I spoke with Brayden the other day and he told me NOT to run the PPE Boost Controller with the Cheetah turbo. Thus, it looks like I will have a Boost Controller for sale if anyone is looking. May include the PPE Xcelerator programer if someone is interested in that too.
