So I am planning to plumb in a PS cooler on the low pressure return line from the steering box to the reservoir. Being that the cooler would be after the steering box is there any issue using a cooler with larger lines? The cooler I am looking at has 10an in/out and I was planning to just use an adapter to run the normal 3/8s line to and from.
I assume the LP line going back to the res doesn't need to maintain a certain PSI?
Cooler: https://www.summitracing.com/parts/sum-331116/overview/
