Power concern
wes06dmax
Feb 23, 2009
1,367
37
South Central Kentucky
was also wondering if anyone has any slick tricks to check for boost leaks. i hear my turbo spool up but it seems to just make noise... doesnt feel like it is making a big difference from when im gently accelerating or too the floor
Very cheap and easy to fix all you need is air build up to about 40 psi and spray all boots intake even check the EGR with soapy water if nothing is there check exhaust manifolds and up pipe all exhaust manifolds and uppipe gaskets
picture.php
Burn Down
Sep 14, 2008
7,092
Boise Idaho
I can't remember for sure but I thought my truck stock would do 21-22 psi. Maybe you should test the intercooler and pipes like wes06 suggested.
FamilyWagon
Jul 7, 2010
69
Western Mass
picture.php
did you justdrill and tap for the fitting? i have the PVC just need to get another hose connector and i will give this a shot
