Ehh, front and rear ranch hand bumpers 450ish LBS, B&W gooseneck hitch 100LBS, subwoofers & box 100LBS, amp, then sound deadening and MLV alone probably add 200-250lbs, congnito centerlink and tie rods probably add 20-40LBS, my modified 246 transfer case weighs 100-110lbs vs the 80-90LBS the 263 does, then between the steering cooling, custom lift pump set-up, OO wiring probably 100LBS there. I'm sure the LML 20s and adapters added a bit of weight too.
I weigh 150-160 generally so at least 1100LBS being conservative over a stock one. The rest I couldn't tell you, that's just what the print out said at the garbage place once I left. I think I was 83xx with around half tank, I'd have to find the printout to tell you exactly.
