Plumbing from Lift to CP3
Wikid
Machinist and Know things
Oct 21, 2016
88
Texas
Hey guys, My motor is out getting machined on and I am going to be upgrading almost everything on the motor. I wanted to remove the current fuel block and plumb my CP3 directly. I can just run a -8 line straight from my LP to the CP3 correct, no need to tie it into the return?
I only ask because I wasnt sure how the current fuel block works as it has the main feed and returns in the same block.
I will be building a manifold for the returns from the CP3, both injector banks and the fuel rails. into a single manifold and a -6 back.
Thanks.
dirtymax36
2nd place is last
Apr 11, 2013
367
Yes, you can. just make sure you can go to napa or somewhere and get the better micron rating filters for the lift pump. This should be really easy especially if you can make your own return manifold
Wikid
Oct 21, 2016
88
Texas
I figured it worked like that just like to verify. And definitely going to a finer filter to take care of my new cp3. Thanks
