Please help!!!!! Tie rod sleeve trouble
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Got my sleeves on no problem, but the threads on both sides of the tie rod ends seem to be F&*KED. threaded on the end nuts by hand as far as i could get them, then started with the rachet wrench... they never got any tighter and seemed striped, so i tried to loosen them and they just turn and turn and turn and never come off the stud. so now when the truck is jacked up off the ground the rod ends have alot of free travel where they connect to the wheel assembly. also i can now look out the drivers window and look at the tire when im sitting at a stoplight, i turn the wheel back and fourth and its the total opposite of smooth... the tires have a dead spot in when turnin back and fouth ( from where the bolts arent tight).......
anybody else have this trouble??
by the way there is NO way i striped the threads from over tightening, unless my fingers are stronger than an impact gun... and the threads looked perfect shape when i started the job.
any ideas on what needs to be done now???
2500HeavyDuty
Book 'em, Danno!
Feb 14, 2008
2,209
Katy, Tx
www.myspace.com
do you hold the tie rod still when your are losening the nut? the tie rod will spin.
im confused on how you worded it, but you have the slevees and the lock nut on there on each rod?
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
the sleeves replace the nut. If you have the nut on there, I dont see how you could have got the sleeves and tie rod end back on where they are susposed to be (theres no room unlees yo uhave short tie rod sleeves).
Also I am not understanding what you are trying to say?
did you get the tie rod end back tight to the spindle?
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
the nut im talking about is the one he is NOT wrenching on.... jsut to clear things up.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
i only got the tie rod end tight with the inner tie rod. i cant get it tight where it meets the spindle
maxaholic
1,876
40
Central, Texas
I left the nut on mine. I used the nut to jam the sleeve and do the alignment.
maine04max
Dec 11, 2008
1,009
I have the adjustment nut and sleeve on mine . If i understand correctly you cant get the nut tight on the top of the tie rod where it connects to the spindle???????
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
yes. if the spindle is the little hole on the brake/wheel system then YES
sorry i didnt know forsure what that was called
maine04max
Dec 11, 2008
1,009
like said above you should be able to get a small wrench(10- 12 mm iirc) on the stud that goes up into the whole . the reason I know is because mine would not tighten up either cuz of corrosion up here in maine . if you cant get a wrench on it any pliers should work as there are no threads way up on the tip , once you get the tie rod somewhat tight it will stop spinning and you can snug up as much as you need
