I have been experiencing issues with loss of power/mpg on my lb7. I checked the rail pressure's desired vs. actual and there is a few thousand psi. And I can definitely tell a difference in power.. I tested by raising the fuel regulator in my EFI Live program, to 160*. Desired was 23,xxx K and actual was 20,xxx - 21,xxx K.
So CP3 or FPRV?
Next is the bigger issue I am concerned with. I pulled my oil cap to check blow by and as soon as I pulled the cap off I heard what sounded like a bearing whistling. I feel like it's likely to be the main bearings.. Any suggestions? Is the whistling normal? I don't have time to take this thing out of commission for more than a Sunday. It's my only transport to work. In a month or two I will have a new truck and I can do what needs to be done.
Thanks for any help
So CP3 or FPRV?
Thanks for any help
