Planned build
paint94979
Beer Nazi
Sep 18, 2006
11,715
So after debating on what to do with my engine for awhile I decided to just build the damn thing. Back in March my truck with a slipping transmission made 649hp which is down 52hp from the same tune and dyno. I kinda miss racing .:D
Parts:
Exergy 60% overs
Carrillos
Cut stock pistons if they show significant signs of abuse I'll grab some pistons from Fingers
Alternative firing order cam mild no reliefs required
Hamilton springs
Head and main studs
Gasket kit
Bearings
Probably call it a day around 850hp but you never know :D
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
Once you have the motor you will push it! Start out with finger's pistons and a set of 100 overs and save yourself time and money a year from now!!!
paint94979
Beer Nazi
Sep 18, 2006
11,715
Haha I have said I'm building it for years... This time I'm serious. I've got the money set aside for the emergency if it popped well it's cheaper to do it while it's running
paint94979
Beer Nazi
Sep 18, 2006
11,715
100's unfortunately smoke under light throttle and considering I'll be running a big single I'll probably stay with 60's... California's fines are huge for smoke
S Phinney
4,008
Quncy, Fl
100 overs can run as clean as 60 overs. Going bigger then you really start running into more of the smoke at intermidiate throttle.
5,815
when you send me pics of it out and apart, ill finally believe it :D :D
keeping the single 75 on it for those goals?
paint94979
Beer Nazi
Sep 18, 2006
11,715
I thought you meant PW... Turbine is 83mm. I'll probably have the turbo rebuilt and go to an 87mm cause that's the cheap part in a build
