I have a question regarding where the piston ring's end gap should be spaced. My Haynes manual has the top and second ring end gap 180* across from each other and it has the oil and oil expander ring gap 180* across from each other. They're perpendicular to each other.
The only thing that the sheet that came with the rings states is that the oil ring and oil expander ring should have the end gaps ~1" apart.
Which way should it be done?
