with .012 -.013 piston protrusion on all cylinders and stock pistons just delipped . block was milled but pistons tops were cut to keep protrusion down to the .012 . the bores were also punched out .020 . I know the spec section says to use c gaskets . but im concerned with too much compression . iirc Ive heard that just delipping doesnt lower compression much . do you guys recommend D gaskets that are .008 thinker to keep compression down ????? or should the bowls be open more to lower it so i can run higher boost ???
thanks in advance Craig
