Anyone use 50/50 Acetone and ATF as a penetrating oil? i read in Machinist Workshop that it was by far the best stuff to use to break loose bolts and nuts... im trying it now on my up pipe bolts
What's the average load mean?
what is the flash point? The benefit of the liquid wrench,kroil et al is the high flash point, you can spray it on hot parts without worrying about losing your eyebrows.
good question... i have no idea it sprayed it on right after the engine was up to operating temps and i didn't experience a single problem.
apparantly guys that have the April/May 2007 issue in hand say the magazine made a huge typo and in fact they used Power Steering Fluid/Acetone 50/50 not ATF
Update:
after spraying down my up pipe bolts with the Acetone/ATF mix
So which one is it?
Aren't ATF and PS fluid VERY similar?
