paint the firewall?
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
whatcha think?
My truck is currently burgendy soon to be flat black
what should i do with the firewall and the lil bit on the fenders?
and no there isnt any of that insulation crap;)
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
64
Norco CA
www.mcratracing.com
White will show exhaust leaks the best.
Does it ever. :(
Technically white makes the most sense:
Heat rejection, white does not absorb as much heat.
Light reflection when working.
Write notes on it.
Shows leaks best.
White is in fact, faster than other colors. ;)
partsguy662
blowup doll salesman
Aug 14, 2006
377
Gold plate it:D
There is that silver heat tape in big sheets that i could stick to the wall
that would make it nice for checking for leaks
All I can say to that is.....
please
:hehe:
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
ju culd eenstall sumz z diamoond plate metal no?:joker:
Gloss black might not be a bad idea, not so good with heat etc. However when the exhaust hits it, leak, it'll fog the finish and you'll pick up the leak. Unfortunatley water spots EVERYWHERE.
They also make an underbody paint that's almost flat black, resists rust and will paint over with no primer. $$$ $70 per gallon
Good luck with it.
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
I went with silver high heat paint:)
Then kicked it up a notch and placed some heat sheild from DEI this stuff sticks great and molds easy. You need tinsnips to cut it, Part# 050501
Its a little thick but before i painted i took a sledge hammer to the firewall and beat it back about a inch or so to make room for bigger pipes
http://www.designengineering.com/products.asp?m=sp&pid=27
Ill try and post some pics tommorow
