LBZ: P268a
cat_dr.
257
Jackson,Al
just started getting this code on my truck today. Hooked scan tool to it and it says injector flow rates not programmed. Anyone ever seen this or can tell me how to fix it.
ryan415
Oct 24, 2012
371
860
Both the ECM and glow plug control module must be programmed with the correct fuel injector flow rates. For whatever reason yours is not, you can see with a tech2 which module isn't programmed and then copy the flow rates to that module from the other. Not sure if this can be done with a v2. Hope this helps a little
cat_dr.
257
Jackson,Al
I have a snap on solid scanner I just need to know how to reprogram it and not scew anything up in the process
ryan415
Oct 24, 2012
371
860
May possibly be caused by a glow plug control module internal memory loss or failure.
ryan415
Oct 24, 2012
371
860
I've used a modis before but never to do this so I'm not to sure. But there should be some type of special function or module setup as in a tech2
cat_dr.
257
Jackson,Al
It is I found it and am trying to fix it now. I just got this scanner and haven't completely figured it out yet
cat_dr.
257
Jackson,Al
It's giving me an error when trying to copy them from gpcm to ECM. It's showing the rates as all F's. does that seem right?
ryan415
Oct 24, 2012
371
860
No can't say I have seen that. Not sure if a failed gpcm would cause that, I've replaced them before but for different concerns. Only other way to get the flow rates is from each injector I believe.
cat_dr.
257
Jackson,Al
After trying to copy them I'm now getting a P160C code and as soon as I clear it it comes right back
ryan415
Oct 24, 2012
371
860
P160c-engine calibration not programmed-gpcm. Basically the same as the other code but is saying that the flow rates are missing from the gpcm
ryan415
Oct 24, 2012
371
860
You can try having it programmed and see if you can get the flow rates back. Otherwise you'll probably end up replacing it and the only way to get the flow rates is off of the injector bodies unfortunately. Or it may just be a issue with the solis, try programming them with a tech2 if possible. Sorry wish I could be of more help.
cat_dr.
257
Jackson,Al
How would I go about reprogramming gpcm to get rid off the code. Im really wanting to get this thing fixed and get the light to go off.
cat_dr.
257
Jackson,Al
Where are the flow rates located on the injectors? Would I have to pull them to get the number or is it one of the numbers on the top of the injector?
