P0847 p0700 code
marc75
111
ok thank you Mike you were right the plug was fall out from the transgo convertor flow valve i took one of 06(from a trans that i refresh with new valve but keep the old one) but the size was not the same so i took the complete pump but keep the separator plate with the .47 hole now the conveter is ok but still get these code P0847 and P0700 when i put it on R it goes on neutral and on the lift if i put it on D it like to start in 3 shift one gear anf then the engine light come up. I change the TCM (05) and i see only the light in R in cluster and same problem but get other code 2810 and 843this time. btw the pressure swith is the same 5 and 6 speed?? because i put a 6 speed in (same as pump) NSBU switch ??? thank you for your help
marc75
111
thank you Mike you're the men i found another valve body and swap it everything is ok now i ll check the old one tomorrow i think is the valve E is stuck. thank you for your help
