P0540 code.
ronsway
Sep 9, 2009
2002, 2500HD, 4X4, auto - I am getting a P0540 code. I have heard that it is the IAH relay. What can I do to further determine the problem? Is this something a "bolt-on" mechanic is try to fix?
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
That is what the code is for
If the temp of the truck is under 121f and or intake air temp is below73f it will kick on the heater coil
Check the voltage on the heater coil and that will tell us where to start,there is also a wire on the glowplug controller that need to be checked that will elimnate the wire to the plug being the issue
bigblackbronco
Oct 7, 2009
code p0540
OK, the most common thing that sets code p0540 is the air intake relay.
the thing most people don't realize is you don't have to replace this whole box
just take the top off, and what do we have
as you can see it is actually just two separate 70A SPST relays that can be had for $5 almost anywhere on the internet
I hope this helps, if you want to test the relay's there are plenty of how-to's on the internet, but I would just replace them both.
