P0193
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
fuel rail pressure sensor high voltage. I'm trying to start the truck and this is the code I am getting....
also B1004 and B0159 any ideas?
13,699
751
Did you get your fuel pressure regulator plugged in good?
B1004 is supposedly some sort of "keep alive memory reset" code, and B0159 is "outside air temperature sensor range/performance" or something like that.
13,699
751
The one that goes down to the regulator on the CP3. Not sure how it is on the LB7s, but on the LBZs there's acutally a short pigtail that goes between the engine harness and the regulator. So you need to check 2 possible bad connections.
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
seems to be fine, I unplugged it and plugged it back in, the truck just cranks and cranks like its not getting any fuel and there is the P0193 code....
13,699
751
What kind of rail pressure are you seeing? When I first started my truck after having it out for the first build I had a buddy of mine pump the filter primer while I was cranking on it to get fuel.
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
not sure, I have a MITUSA and I primed it quite a bit, when I crack the bleed screw on top of the filter housing the fuel is under some pressure there, the high voltage thing concerns me a bit....
13,699
751
I'm not 100% sure, but I think it's on the driver's side.
13,699
751
The rail pressure sensor being unplugged could keep it from starting. It won't know it doesn't have enough rail pressure to start.
13,699
751
So does that mean it's running now???
edit: Just saw your other thread! Glad I could help.
