Hi, new to the forum.
Spent a lot of time researching before posting. I have a P0090 (Fuel Pressure Regulator Control Circuit). I am using a Launch scan tool.
Upon getting DTC, the tool took me to the "live data" and everything there seems perfectly ok when I compare "desired" and "Actual" values.
I couldn't not delete the DTC with engine running or off. As the DTC specifies "Circuit issues", I unplugged and replug the FPR, move the harness around and was able to clear the code after that.
So, looks like it could be a bad wire buried in the harness somewhere.
Would anyone know or have access to a proper wiring harness schematic and could tell me what wires are used by the ECM to monitor a P0090 code?
Thank you
Thank you
