Hey All,
Truck is a 07.5 LMM, Deleted, 150K, truck sees 3000RPM daily and is typically driven in tow haul for city driving.
Need some guidance or assistance. I have recently come into a P0047 code and i'm at a loss for words. Truck does not have any other codes. I have done the following;
- Checked the wiring from Terminal A to pin 48 and reads 4.5 Ohms.
- Terminal B to pin 96 and get a reading of 4.5/4.6 Ohms.
- Tested the pins to the engine for a short in either circuit in both directions I get - infinite resistance.
- Testing across the VGT solenoid I get 4.6 Ohms at roughly 30*C oil temp
- I get 8V across terminal A and B on the harness with key ignition on.
- Fuse 19 see's battery voltage across the fuse while running and with key on.
Vanes are currently in 0% position with a 9% request at idle. I have no way to command the vanes currently. Could the solenoid still potentially be hooped?
Thanks, Matt.
Thanks, Matt.
