opinon what is considerd a built motor
what makes a built motor
  • rods
    Votes: 8 15.1%
  • rods _ cut cast pistons
    Votes: 9 17.0%
  • rods + apr fasteners
    Votes: 4 7.5%
  • rods+ MS+ cut cast piston+HS+ worked heads
    Votes: 32 60.4%
  • Total voters
    53
550
stock no
mild built IMO would be a better term for it.
since in my case only thing that one could say was imporved are the woodruff keys, rods, and main studs. everything else is stock grade including the .040 over LB7 cast pistons
super diesel
<<<< Under Pressure
I belive built is built. I'm sure where were at now is a far cry from built 2 or 3 years down the road though. I'm not running the new HD main caps (yet). The rods and head studs is a great start (inject hold downs and studs on LB7 go hand in hand with this too). This is good insurance for the budget build. I would be scared of having confidence and blowing it again if I only did this. I know me.
SmokeShow
6,818
Lawrenceburg, KY
I'd say yours is a built engine. Mild, but nonetheless, built. IMO once the rods are swapped and pistons modified, it's built.
Fully built would be that last option - rods, pistons, cam, heads, injectors, etc.
C-ya
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
anytime the engine has been opened up and any parts changed, its "built" IMO.
even just throwing rods in, I consider that built; there are non-stock parts in it, are there not?
I used to have a "built" motor. It was fun.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Seriously, I'd say even just rods would be considered "built". Not to be confused with fully built, or built like a brick shiithouse, built ta da hilt. Most folk who modify their cars, trucks, bikes, don't go into the engine.
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
IMO- its built when you have replaced all the parts known to fail with better parts. For a DMAX rods and pistons, what else fails?
I think this topic runs a parallel with what the definition of "streetable" and "daily driven" is, its based on opinion and a modicome of common sense or lack therof.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
X2, Im with Pat.
Ive used built
and
Fully Built
Built = Pistons or rods, or both
Fully built = pistons, rods, headstuds, and at least 3 more HD parts lol.
