Opinions on a budget/street engine re-build
slowlmm
Mar 2, 2008
2,582
46
so cal
a cam is around 800-1000 and will help with spooling a bigger turbo. Imo its worth it i like the diffrence it made in my truck and i havent evn got a bigger turbo on it yet :D
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
slowlmm, your cam suggestions really got me thinking....... What's the "powerband" on your cam? I did a couple quick calculations, and if I extend the usable RPM range of the engine to 4200rpm here's what I come up with
1000ft/lbs x 4200rpm = 4200000.......4200000/5252 = 799.69HP
1400ft/lbs x 4200rpm = 5880000.......5880000/5252 = 1119.57HP
1000ft/lbs would surpass my goal and a built motor shouldn't have any problems staying together at 4200rpm.....With 4200rpm larger than originally planned turbos could also come into play....:D
721
gasser math doesnt really work with diesels.. 500-500hp is 950-1100ft/lb on a dmax
duel cp3 + 4088= 620/1200 easily
1000hp is roughly 2200+ft/lb
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
I thought that these are standard formula's that apply to all engines gas or diesel........ Is that incorrect?
(torque x rpm) / 5252 = Horsepower and ( Horsepower x 5252 ) / rpm = torque
slowlmm
Mar 2, 2008
2,582
46
so cal
900 rpm to 3500 so far :D when i get a bigger turbo i will probbaly be running into to the 4000 rpm range I think tuening has alot to do with where your power comes in as well. All i know is with the combination of parts i did even with a stock tune the truck was pretty darn quick. now with a decent size tune but smaller then wht i was running. its running as quick as it did with the cheetha and 40-94 on the truck.
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
You're still running a stock turbo correct? Basically what's happening on your truck is the stock turbo is maxed out at 3500, correct? I am planning compound turbos after the build since this is my daily driver and I drag race more than truck pull. Even when I do pull, the pulls are small time local pulls with no teching or rules really :rofl: ..... As for the compound turbos, primary turbo will be an s480 :D.... Airflow will be plentiful
slowlmm
Mar 2, 2008
2,582
46
so cal
yep stocker still :) not its not maxed out at 3500 tht wht i have my rev limiter set to its nicer to the motor :D unitill i get back to a dyno i dont know where the limit of the rpm range is with the stock turbo.
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
Update.....I have another LMM motor here, I'm going to start the build immediately and swapping this motor with the one in my truck. After hearing about the piston failures lately, I've decided to try and get a motor built for this summer. I got a very clean LMM from Tim at St. Joseph Diesel, just picked it up and brought it home today. I'll start tearing into it soon.
LBZrcks
Jun 2, 2007
5,297
12
SoCal
:nopic::D
LBZrcks
Jun 2, 2007
5,297
12
SoCal
the fuel lines look like they have some sort of diffrent conection type on that new motor you got. they dont look like the push lock :confused:
Looks like they put JIC fitting on there, probably since it was never in a truck and on a dyno they use different connections for a different fuel source.
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
yeah, they are cap's......there is an EGt probe in the pass side exhaust manifold, too.......I know it was a test motor, just hoping that it is as clean on the inside as the outside.
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
well the oil pan and rear cover are off and I got this engine onto the stand. Kinda short on time today, but i'm going to try and have the topend toredown by next weekend and inspected.
