Ok so i got the truck back together, just finished with twins, 3788r over S475. I have fuel to the IP, but no start. When i crank it, it will turn over for about 4 seconds then stop.
I redid the return and feed lines so i'm not sure if it could have to reprime itself, but i have tried starting it plenty of times already.
I unplugged the FCA hoping that it would max pressure and start, but no luck, still the same short crank time.
The truck is returned to 100% stock programming so i'm not sure if that has anything to do with it. I'm 98% sure I have all the sensors plugged back in but I do need to go over it once more.
I don't have a tuner or scan tool to be able to read RP so i'm kinda in the dark on this one.
Anyone have any ideas?
Thanks in advance
Kyle
Thanks in advance
Kyle
