Do these have that disc that sits in the center like the earlier Versions???
Any Damage to the convertor???
Yea, same as all the others. Big spacer/washer.Do these have that disc that sits in the center like the earlier Versions???
I didn't see any issues taking it apart. Not sure what to thinkThose look like fatigue cracks due to constant flexing. Id make sure the transmission was seated to the engine correctly and flush. Also no debris or anything stuck between the converter and flex plate or transmission and engine. Just a small amount of continuous flex due to a misalignment can do that
Nope, that was assumption all along but they were tight.Loose converter bolt(s) is my next guess. But you already mentioned those
How did that look when it came off? Was it seated properly when you went to remove it?Yea, same as all the others. Big spacer/washer.
It was installed correctly and everything. It has all the break/crack marks on it. I'll post that tomorrowHow did that look when it came off? Was it seated properly when you went to remove it?
That is more what I expected the HAZ to look like. The previous one is too small makes me suspicious if it even is heat relatedAnd this is after map gas torching directly on flexplate for 20 seconds
