Oil in Coolant
estoniaboy
Mar 26, 2013
Hey,
I got LB7 Duramax that has oil in the coolant, but not coolant in oil. Engine oil is bark/black as it can be while the coolant system is nasty mix of oil and coolant. Has anyone ran into same problem as I am having? What could be the problem?
On top of the oil in the coolant there is significant pressure in the coolant system, the cap wants to fly off the overflow tank when loosened, shortly after engine crank. The engine its self runs great, no odd noises or anything.
I personally think it is the head-gasket, but I am also thinking perhaps it could be my oil cooler or..?? Any help/advice/thoughts would be greatly appreciated.
Thank you.
estoniaboy
Mar 26, 2013
Can you have head gasket(s) blown and not have coolant mix with oil but have oil mix with coolant?
jkholder09
Jan 8, 2012
1,188
Maryland
what about trans oil and radiator intermix, dmax cooling systems sometimes have some pressure.
block tester available to the original poster?
dirty_max
815
eureka il
A oil cooler isnt going to pressurize the overflow tank and try to blow the cap off. Its getting compression in the cooling system.
Galaxy S3
im not trying to start and argument but yes it can. if you have oil in your coolant then there is an increased volume of liquid in the tank. how high does oil pressure go? long story short, an overful overflow tank will push coolant/be overpressurized. this is coming from just my general knowledge of the diesel engines that i work on everyday, not specifically the dmax. also, im wondering how a popped headgasket can put oil in the coolant? ive seen some pretty nasty coolant from combustion gas being in it.
03BlkMax
Jul 15, 2012
125
Kentucky
Well, good luck with your theory. Lol. Guess youve never had a dmax blow a headgasket before. Guess we'll see what the op finds. ;)
Galaxy S3
dirty_max
815
eureka il
no I haven't, but I have had a few hundred semis with blown hgs, and bad oil coolers so its not really a theory anymore, its pretty much been proven. there must be something super special about the dmax and how it puts oil into the coolant when they pop :roflmao: it does sound like he had bad hgs, but I still don't understand how it gets oil in the coolant from a blown hg. it just doesn't make sense to me yet and I would like you explain how combustion gas going into the coolant leads to oil going into the coolant. I can see coolant going into the oil with a bad hg, but not the other way around
03BlkMax
Jul 15, 2012
125
Kentucky
Since you seem soo well versed on this engine. Let me ask you this. Is 15psi greater than 40+psi? Lol
Galaxy S3
estoniaboy
Mar 26, 2013
Then maybe I have both the head gasket and oil cooler bad?
Has anyone had a blow gasket where oil got mixed into coolant but not the other way around?
Jul 21, 2013
chocolate milkshake lb7
Iam having a simular problem. 2003 dmax Still trying to figure out the cause of all this milkshake. Engine oil is clean and full with no sign of moisture. Allison oil is 1 quart low. Pulled oil cooler out and no signs of any leakage. Gonna have to replace bdcause I split ghe housing from the he cooler. Getting a pressure checker today to re fill the sludgy mess with water. No excessive pressure coming out coolant tank. Any more ides? I do see ghat the tranny
cooler hoses run to the radiator and then to a separate tranny
cooler up front. Are the lb7's turbos water cooled? This whipped mess is definitly chocolate.
