LLY: oil cooler pipe removel
jer
Jul 27, 2012
replaced the water pump on my lly today started it up and anti freeze pouring outta the oil cooler pipe from oil cooler to the outlet of the water pump.. disassembled and tried getting the pipe out. its loose but wont come out. is it flanged on the inside? do i have to remove the oil cooler? need help
jer
Jul 27, 2012
Yea I can see its tricky n enough to piss a guy off.. I has a pry bar at the end of the flange with all.my weight on it n the s.o.b is still in there.. I gave up for the day
jer
Jul 27, 2012
Water pump was already out.. I finally got it after some finesse. Does anyone know the part number of that o ring?
jer
Jul 27, 2012
Well I got it off by prying again the end of flange with a 4 ft pry bar against the block but now the? Is how do I get the s.o.b back in.. I lubed it up n tried pushing it in but that's a no go.. go nothing to pry against n no room to git the end with a hammer
db89149
Jul 31, 2012
just replaced oil cooler, took studs out of wp flange, got water crossover started by need about 1/4" more . is it possible to back of the three wp bolts to get a little more? thanks for any help...
