Hi everyone, Mike here, so I am new here, not normally needing assistance, but this one has me in a loop.
2005 LLY 242K 6.6 diesel STOCK
A little history - 2 transfer cases replaced - drive shaft seals replaced -drive shaft re-balanced - egr delete - misc maintenance water pump/fluids/brakes and thats it !
So the problem started out about 8 months ago - wouldn't lock into 5th gear and when mashed on the pedal the passing gear (dropping down to pass) wasn't happening, slow and sluggish .
Following that 1 month later after 30 minutes of driving truck wouldn't come out of 3-4 gear, unless it was neutral or park and reverse.
This Month, now that the weather is tolerable - dropped the pan - no debri (or material)- fluid is a beautiful red - replaced all the solenoids with OEM, but during the investigations under a plate (Trim solenoids) there are 2 springs, 1 was broken into 3 pieces. replaced both of those springs as well as the Psm and the MLPS switch on the outside of the transmission, plus a new wire harness ( found mine was leaking trans fluid during the inspections )
So none of this stuff was replaced by me or anyone else since I had purchased the truck 8 years ago, so I figured now was the time to do it since Im dropping everything down.
Well that fixed nothing.
First it was shift inhibited when I finished up, so
I replaced that electronic lock in the steering column (no change),
checked all the fuses, (they are good),
Fluid is full
Checked the pins on the TCM (seated tight)
relearned Transmission
I reset the main TCM harness and cleaned it up, and the Shift inhibited went away, I was able to drive the truck and it was movin, like I havent felt in awile, had power, nice shifting, everything was great in the 20 minutes I drove it .
Wife jumped in it and drove another 20 minutes and it went out of gear and then locked into 4th.
along with that 22 Errors .
Its sounding like a communication problem ... but I am not sure... I keep thinking the TCM is screwing up judging by the codes she is throwing at me ... but again I am unsure.
Anytime you start it up throw it into reverse - no issue - neutral - no problem put it into Drive and she will sit in 1st gear for 20 seconds then you hear it shift into 4th and lock, just sitting there idling not driving.
Fluid is full
