what in the world were you doing under there that it took that long?! lots of beer breaks?
I was wondering the same thing. I could understand beer breaks though.
Installed the led flasher.
Novita LM487 Flasher https://www.amazon.com/dp/B001KS6GIG/ref=cm_sw_r_cp_apa_fIECAbCMRK1N6Did you get it from the dealer for the Chassis trucks?
I figured while I was in there and it needed it , I turned the rotors down , still had alot of meat on them , cleaned up the caliper bracket , new bracket boots and caliper bolts , lubed it up and the slot that the new o ring goes in knuckle goes was full of rust , so it took alot of time to get that all cleaned up to put in new o ring with lube , put in new brake pads . I didnt think I needed to go in depth but since you asked . I think the guys name it Mccall that posts about brakes alot would be proud of the job , but to you experts its just an everyday thing !
ha! experts.... :roflmao:
Well most of you guys have more experience on Duramaxes than I do , so I appreciate any new thing I can learn from you all ! With my limited 6 years experience on strolling this site and working on my truck, if I can be of any help I am more than happy to try !
Well Mike Ls trany cooler just showed op at the door , time to get to work protecting Evans trany ! It is so great having knowledgeable people on this site to answer questions ! Thanks again guys !Sounds like one of my brake job. Well while the trucks jacked up I might as well rotate the tires, which requires sniping them again, look the wheel wells look kind a rough so I need to clean those up real good and hit them with some undercoating, now would be a great time to grease everything too and etc. next thing I know my brake job turned into A full days work.
Getting my GMC ready for a line X bedliner I prepped the bed rails and pulled all the plastic all the way around to have it coated also ordered a brand new set of three step n-fabs having them spray those while There at it before I install I will post of a picture after it is complete
Fixed my MBRP exhaust that cracked in half from rust.
your not old, i want to run my exhaust the rest of the way out the back of the truck. two turbos and a muffler kill 90% of the drone but im over hearing my exhaust all the time when cruising. ill leave the noise makers to my toys.
on a side note, jacked the front end up yesterday on the truck. Found a wheel bearing starting to go (RF this time, has about 110k on it since it was last changed) and the idler arm support is pretty worn. everything else is tight. might be time for a kryptonite idler arm support finally.
