six5creed
1,046
58
N.C.
That is a beautiful picture!
baggedLB7
Goer
May 1, 2011
688
Utah
On my way home from work the other night and I go to stop at a light and the break pedal goes to the floor. Luckily I wasn't going fast and was able to get it stopped. I wasn't to far from the house so I limped it home. Crawled under it and found the seven bolts holding the track bar mount to the diff broken off in the rear end. This also caused a brake in the hard line for the rear pass break.
Not sure what caused it as I cant think of anything out of the ordinary happening. It does look like the track bar end has gone to s*** but cant imagine that would cause or have enough force to break seven bolts off.
Should be fun getting the broken pieces out of the rear end.
Electro-02gold1ton
Super Dually
Nov 15, 2015
35
ABQ,NM
Okay so it's been a long three weeks of putting stuff on the truck, finally feel confident to hit the road again. Here's a list of what went down.
New Misimitto intercooler piping
DHD Ported turbo horn
EGR blocker plate
AIH delete
AFE Momentum HD
DSP 5 with ATP tunes
BD Diesel Tapshifter- Overdrive L/O indicator is above boost gauge. Waiting for new module first one crapped in two days for some reason it should be here today.
She got new toyo AT 2 shoes with Bilstein 5100's all the way around
And a much need bath to wash off the 9500mi or so. Here's some pics
04chase
222
Been a very busy year for me, between my cadillac, my non stop growing shop and tools and my lbz .
In the process of my cognito 4" kit from the uca leveling kit. Doing 1" blocks out back and fox shocks all around with a red head steering box .hope to finish today . Proud of myself , my 170 lb ass somehow man handled the front diff out by myself .
so in the past month this is the list
Built 6 speed by inglewood with billet goer end converter
3794vs stage 2 billet turbo
Lml driver manifold w heat shield
All new gaskets
Added coolant drain valve
Atp updated tune w dsp5
Added expandable egt and boost gauges and sensors (removed intake and tapped under side to be hidden)
Red head steering box
Made my own p/s lines (welded jic fittings to hardline and crimped hydraulic hoses)
Pcv re route with gates heat shrink hose clamps to look more discreet
Fass 150
Beans sump
Nicktane w 1r-0750
Cognito 4-6" kit set at 4" w fox shocks
1 " blocks with hd u bolts
Ss brake lines all around
New fluids all around
New moog pitman arm (had napa hd pitman ,which is larger but not forged)
Not quite everything sis done but hope to drive it today after its off the rack .
Nw just need a bed liner, 01-02 hd hood, and possibly a way to soften up the rear without loosing much towing capacity and adding axle wrap
I've built this truck and made it too withstand many years of ownership. I
Sent from my SM-G900T using Tapatalk
D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,112
13
Phoenix
Cleaned up Nightmare and The Screamin Demon.
Not bad for 200k miles
New mounting tabs some paint and 3.0 Ballistic Joint.
Just hit 17k miles
Not a truck but I did jump back on my CB/VFR900F for a few hours last night. Shop is a mess again!
'06 '07 LBZ's
Owner of ShopSource.com
& Evil Arc Fabrication
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
Just hit 17k miles
'06 '07 LBZ's
Are you still working on marketing that rear AirBag and Link kit yet?
D-MAX Mafia
Nov 4, 2009
1,112
13
Phoenix
Not anytime soon.
I just started a new business and all my time and money is going into it. So at this point designing/manufacturing a kit is not possible.
I do have a couple trucks that I'm going to build 3 and 4 link kits on at my home shop for close friends when I get the time. On that note, setting up a weld on kit would be much easier. However, with the amount of fabrication that is needed I don't want anyone with a Home Depot mig welder trying to do it at home and then coming after me when they have a failure.
'06 '07 LBZ's
5,928
Not anytime soon.
'06 '07 LBZ's
I best be one of those friends! Lol
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
Just hit 17k miles
'06 '07 LBZ's
Nightmare!!! How she running?
