Nozzles vs Whole New injectors
S Phinney
4,008
Quncy, Fl
They wont sell you nozzles by themselves. You either buy new Bosch, remans or send them yours but your not guaranteed to get your exact ones back all the time.
Since when do you no or get yours back. They track every serial number that comes into their shop.
9,905
151
If yours don't test good or can't be repaired they send you good remans instead. It's happened to several people and it says it on their website.
S Phinney
4,008
Quncy, Fl
I understand that. You implied they may switch up others injectors with the ones that you sent in.
9,905
151
I didn't imply anything.
That's exactly what they do if yours are completely trashed. If yours are good then they send them back. Sorry if some didn't catch that.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,538
526
Central OH
Wouldn't a normal person send in the whole injector to get them balanced together? If you say all your injectors are fine, and just going to slap nozzles on, why not spend a couple hundred extra and have them install the nozzles and balance?
If you are worried about them finding a bad apple, then how do you think slapping on nozzles is going to turn out? Point being, if you're 100%+ the injectors are fine, why be worried about exergy finding a bad one.
9,905
151
Because it's a lot more than a couple hundred more.
~$400 with shipping for extrude hone vs ~$1500 + shipping with extra insurance.
Exergy won't install other nozzles or even theirs without doing all the cleaning, baseline tests, and then the balancing, assy/dis-assy, and so on. Each step with an appropriate charge.
This is obviously the right way to do it if you got the cash.
I'm looking at other options. Originally I was just going to jam the stock ones back in as is then decided a little bigger wouldn't hurt.
I never ever said I was worried about them finding a bad one. That's their job. I had mine tested and I'm confident the shop did their job.
It's all the other costs associated with their procedure I'm trying to avoid right now. Trucks been down for two years and I'm trying to get things going and putting money elsewhere at the same time.
onebaddmaxxx
1,212
Cecil County Md
No worries, iv installed just nozzles on trucks not the whole injector with NO issues!!!
I have even swapped 2 sets of 100% nozzles even and never had an issue.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
The thing I have always wondered is what happens when the injectors have 10-20000 miles. Are all of them going to still be balanced evenly? Seems like no matter what you have a couple that wear quicker. This is where I think it depends on the power lever. We all know we have seen trucks where only a couple injectors got replaced but it still runs fine.
onebaddmaxxx
1,212
Cecil County Md
Whats the difference when you spend buku money on exergys and they get 20k miles on them.. Still think they are perfectly balanced....? Unfortunately, we have no control over how hard parts wear.
9,905
151
Honestly I would be more concerned with having a failure with an injector stuck open than being balanced. When they are out things like smoke at idle when there never used to be are indications to check balance rates. A stuck injector doesn't give much notice and wrecks stuff fast.
56taskforce
1,090
70
:happy: surprised this isn't a big one in the regrets thread.
Yah I plan on doing a lot myself things that many say don't attempt like transmission build but injectors no. When the time comes for injectors the only thing I will do is the R&R the rest will be left to Exergy.
9,905
151
I think the only regret most have it seems it's not going bigger the first time around.:D
FWIW now that I think about it I've heard of more issues with stock injectors and really high PW than people that don't balance the injectors after changing nozzles but that's just me.
bml2200
256
IL
I've went both the Extrude Hone route with 60% over nozzles and Exergy 80% over injectors, both worked fine. That said, I'll be going with Exergy again to do the whole injector when I go 100% over this time.
9,905
151
Call this number and ask for Jim. Kenametal Extrude hone is the business name.
(724) 539-5000
Does Jim have a last name because whoever answered the phone there couldn't find anyone to direct me to named Jim. Or a department would be helpful also.
