Not stuck yet, but close. In Norfolk
N2BRK
2,062
392
I'm home. Squeaked like a bitch the whole way. I threw it up on the ramps and everything eyes ok on the driveshaft joints when I rock by hands. But this gap looks wrong to me at the slip spline!! I'll get a picture...
Harbin_22
3,858
Southern Indiana
Thats normal, just shined up from the suspension traveling up and down, making the driveshaft move in and out. If you want to check the joints, you are going to have to take the drive shaft out and inspect them. Keep driving it and it has a bad joint, might end up breaking the rear adpater housing on the trans.
N2BRK
2,062
392
Thanks. I kinda thought it was ok but I'm a bit flustered. I've been home for 10mins after a 5hr ride home, hoping it would make it. I have to be out at 7am for one aunt's funeral, and then on the way home another aunt died, and my wife's alternator crapped out. I need a vacation from my vacation now, lol.
I'll pull the sob ASAP. Thanks.
oscyjack
May 7, 2016
775
Northeast
That's normal. If you drop the shaft you can polish off the gunk. Over time, a buildup could hinder the forward/aft movement of the skip yoke. Your seal looks good so I wouldn't necessarily suspect the transfer case. The u joints look rusty enough to warrant checking, if you haven't already. You really should pull the shaft and rotate each cup to make sure. It could still be a brake or backing plate issue.
N2BRK
2,062
392
Honestly, I think I'm just being thick. I know it's the ujoints - classic noises. I'll get it done. I just need to find some heavy spicers and an hour to kill :)
N2BRK
2,062
392
Pulled the driveshaft; super easy. Ujoint at the pinion end is the squeaker. I'll do both of course. My only problem now is that I'm trying to find out what clips to use with the spicer 1480?! Oem are too thick apparently.
Harbin_22
3,858
Southern Indiana
Sure you don't have a needle out of place, setting under the cap
N2BRK
2,062
392
No, the joint itself is larger than the 1485 in there, so you either have to thin the caps or the circlips. I thinned the circlips and it's a pain in the ass but it works. The truck is quiet now and goes very side ways in tune 5 ;)
oscyjack
May 7, 2016
775
Northeast
The new u-joint is larger? Which did you buy?
I don't think i'm having the same issue, because it made the squeak with OEM U-joints and with the new grease-able moogs
N2BRK
2,062
392
Spicer makes a 1485 that drops in if that's what you want to do. I took it as an opportunity to put something in that is as strong as possible.
oscyjack
May 7, 2016
775
Northeast
I guess I now don't understand.
The OEM part is the 1485, but you felt the 1480 was a better choice because it is stronger? If it does not fit without modification, is it really stronger?
I'm trying to determine, if while under the truck next week amidst EGR delete, up pipe, downpipe, hot side tube, front u joints, brakes and a tranny service; if I might go ahead and purchase spicer u-joints as well to replace the Moogs I had installed a few months ago on the rear shaft.
The moogs I got were 1480 series, but my squeak is still very present. The Ujoints installed without complication or difficulty, but in the effort to make my truck quiet if I wonder if I should get the OEM drop in 1485 from Spicer and call it a day.
N2BRK
2,062
392
they are stronger and take little effort. It's worth it to me. You can't go wrong either way. If you already installed Moog, I'd wait for them to fail. You're on a stock chager and trans, so that might take 100K, lol.
oscyjack
May 7, 2016
775
Northeast
Not questioning your choices, just trying to get more understanding of specifics when it comes to components. I like to know as much as possible about this stuff.
Why is it the 1480 is stronger? I too went with the 1480 (Moog) but only because it was the part number associated with the truck and not for other reasoning. Soon-ish I intend to start planning for a rear end build, and I feel this info may help me along the way.
Thanks
N2BRK
2,062
392
Why is the 1480 stronger? Simple answer is that it's larger. Longer answer is that it's wider which allows for more strength at higher misalignment angles. Also it has no passageways carved for grease so it's stronger than a greasable unit. How much stronger than a 1485, I have not seen data for torque on the 1485 so I can't give hard data. There are stronger joints but they are for rock bouncers that get lubed after every event; not streetable.
N2BRK
2,062
392
absolutely. When I had it out, the ujoint at the pinion end was the squeaking culprit. I mimicked the squeak in my hands.
