Okay so was searching in the door jam for broken wires then I pulled the b pillar off to get a better look at the plug. I found a mouse nest and all the wires were chewed through.Door lock actuator power and grounds are different than the window motor circuits. However, the one common component between both is connector C396, the connector in the door hinge area which everything feeds through. Also check for broken wires inside the rubber boot, as a previous poster said. Keep in mind, that the wires can break internally from flexing at the hinge point while the insulation stays intact. Only way to verify connection is to use an ohm meter. Also make sure that the door locks don't suddenly start working when the door is open. Broken wires can make connection when flexed the right direction sometimes.
So I spliced them all back together but still no power to the window or the locks.
So I traced the harness across to make sure nothing else was chewed through and found my wires for the air bag so got that fixed.
I didn’t find anything else though.
Do you know which exact fuses would be for that door?
