Noisey 5spd under decel after rebuild
I just replaced a p2 and c2 hub on a 5 speed in a 2001. When coming to a stop from freeway speeds( slowing down in general ) trans will make each downshift properly and quietly until it down shifts into 1st gear. Once in first gear and under decel it makes a noise. Almost like a dry bearing noise, move shifter into neutral noise goes away. Shift back In drive still under decel noise comes back. I'm curious what it might be, and if you've had to deal with a similar concer before. I'm thinking maybe I forgot a thrust bearing somewhere and under decel the plant moves and creates the noise. If I had left out a bearing then I would assume the end play is wrong ? I checked end play on both sides of the trans assembled and were within spec.
Any advice or help would be nice and greatly appreciated !
