no reverse stuck in third. Many codes??
timlb703
Aug 20, 2007
145
This truck is a 2004 4500 gas 8.1. Getting codes p0763, p0768, p0773, p0841, p0871.
timlb703
Aug 20, 2007
145
Truck has reverse sometimes and third gear start. Replaced the nsbu switch will a new one form allison. No change.
Dropped the pan. Have no power to three solenoids. Checked plugs look good.
Took a tcm out of a lly and didnt change anything.
Please help any ideas???
timlb703
Aug 20, 2007
145
This all started because the truck stalled and i put it in nutral and started it pulled it back down to drive and this is what I got.
Mpsoldier
That just happened!
Mar 10, 2010
646
In my House
if the transmission is warm does it do the same thing. i know it may sound stupid but my trans had a simular problem. only did it when it was cold. Once it got warm you can clear the codes and it would be back to normal.
2nd does your shift indicator light come on?
timlb703
Aug 20, 2007
145
yes shifter light is correct and in the correct gears. It started warm and acts the same cold.
timlb703
Aug 20, 2007
145
trying not to sound like a meathead but I pulled the plugs on tcm and am not seeing numbers. It is on a 4500 chevy 8.1 gas.
timlb703
Aug 20, 2007
145
What wire color and location is the 12v power feed into the main plug in the rear of the transmission. I want to make a jumper wire. I don't have 12v to transmission.
