No cruise control
Racerrich08
Oct 6, 2019
Michigan
Hi I have a 03 lb7 and I cant figure out what's wrong with my cc
I watch it on my snapon scanner shows the on /off is working the accel and deaxcel is working and that the set button is working but where it says cc engaged it says no and I replaced the break switch please help me figure this out. I do a lot of highway driving
dndj
Boost!
Apr 13, 2019
302
Oregon
I did inside and outside of truck
Sent from my SM-G965U using Tapatalk
FSM says the ECM inhibits cruise control operation when any of the following conditions exist:
  • A cruise control module DTC (trouble code) is set
  • Vehicle speed < 25mph
  • Vehicle is in Park, Neutral, Reverse, or 1st gear
  • Engine RPM is low
  • Engine RPM is high
  • Vehicle speed is too high
  • System voltage not between 12 and 16v DC
  • ABS/traction control active for more than 2 seconds
Maybe one of these things is sending a false or erroneous signal to the cruise unit. Not real helpful of GM to describe what "too low" or "too high" means either.
dndj
Boost!
Apr 13, 2019
302
Oregon
Schematic
Here you go. Let me know if you want the ABS schematic too which includes the brake light/TCC switch combo on the pedal.
1,866
Last time batteries were replaced? Condition of alternator/charging system?
In real operation, does the CC initially work then immediately disengage or it wont engage at all?
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
CC
Have lift up on the brake pedal as your trying to set the cruise? I have seen the switch cause a problem but the brake lights still work fine.
Benny315
Benny
Feb 11, 2019
86
3
Backwoods, Savannah, NY
__________________
OP says he replaced brake switch... I would check in the steering column next,,, Check the "Tow haul" wire has not broke/rubbing and also the cruise/signal wires as well.
Bdsankey
4,152
1,262
Larsen, Wisconsin
I'd imagine if the cruise control wiring was damaged in the column that the ECM wouldn't be seeing accurate button movements on the stalk but I have seen wiring do some crazy stuff. That's reason #1 I hate trying to diagnose wiring problems.
Benny315
Benny
Feb 11, 2019
86
3
Yeah, wiring issue's can be a PITA... I had an issue with my tap shift/tow haul wire causing odd tranny shift and no cruise either.. A broken wire that is not completely broke or hanging on by a thread can show on the scanner as working, but the amp/volts required may not be met. Just tryn to help..
