What would cause a turbo to just quit boosting? There is no housing damage and minimal shaft play. Turbine on both sides are not damaged. The turbo was leaking oil bad. Went from 21ps1 to 10psi to -0-psi. Could i rebuild this my self?
Yea it barely moves in and out, and does not move up and down!
i have already pulled the turbo and replaced and everything was tight when i was taking it off. and everything is fine now! it took 2 days to get to 0 psi. no borken shaft both sides spin freeley at the same time. a few weeks before it went out it did sound like a un usual humming/whistle at idle that was not there before! boost problem is fixed now. just working on head gaskets! AND TRYING TO FIND OUT IF THERE IS A REBUILD KIT FOR THIS TURBO AND WHY IT QUIT BOOSTING!
wait, both sides spin freely....can you stop one wheel while the other wheel spins
before i pulled the turbo i removed the boost tube on the charge side and when power braked the turbo was not putting out any pressure,
