no boost,help..
MOELMM
Mar 10, 2017
rev it to 1500rpms then i can hear turbo and see boost gauge start to climb.
what can be the problem,my tuner says "turbo postion sensor" i changed it and its still doing the same thing..
any help would be appreciated..
thanks.
4" turbo back exhaust, edge tuner,k&n air intake.
BrandonLLY
116
What does the boost gauge go up to when you step on it? Why do you think you arent making boost?
Awenta
4,090
So what is the problem? You want boost at idle?
MOELMM
Mar 10, 2017
i think i seen 25psi.
after the boost comes on its fine,but no boost as soon as i start driving,then suddenly it will come back to life.
MOELMM
Mar 10, 2017
truck is sluggish for about 50ft, (0 boost) then u can hear the turbo and it will drive fine.
MOELMM
Mar 10, 2017
1/4 throttle, just started to do this..
truck always had boost when i gave it some throttle .
BrandonLLY
116
Did you check for boost leak? Intercooler pipes, v band clamps all nice and tight, especially near turbo mouth piece. Mine has come loose there a couple times now. Clean your air filter and MAF sensor. And you said you changed vane position sensor?
MOELMM
Mar 10, 2017
checked every pipe and clamp,and yes changed turbo postion sensor.
do u think turbo is going bad?
but if it is,why does it drive normal and spools up fine after i drive it for 50ft or so.
it seems like the turbo is dead for a few secs then its back to normal the rest of the day.
MOELMM
Mar 10, 2017
vanes are stuck,i tried to free them up and didn't work..
upgrading to the powermax stage 1 turbo..
Josh154
1,220
85
Sioux Falls SD
If you are going through the expense and time to swap turbos there's much better vgts. The 3794stg2 or the 68stg2r from mark at Danville are phenomenal turbos. They will outperform that powermax all day long.
Or even this turbo if your on a tighter budget. This is the same turbo I run with the high flow vanes option. After you get your core back it's $1700 vs the $2500 other options.
http://www.danvilleperformance.com/dp-tct-2-5-stg2-reman/
