next step
ouellet5
92
Hi guys,
i just did a S475 over stock on my lmm. I'm stock fuel for now and just want to know if my next step should be add fuel or bigger turbo?
thanks
Dirtymaxx03
3,109
That current turbo setup already has the power potential to grenade your motor, assuming its stock. A slightly larger set of injectors may benefit you by allowing you to keep duration/timing down in your tune which helps a little bit when you're pushing a stock motor.
ouellet5
92
are you talking about 45 or 60% over ?
