Newbie question concerning ride quality
oscyjack
May 7, 2016
775
Northeast
Nitrogen has no benefits other than paying the service shop more. It is supposed to reduce oxidation due to less moisture content, be more temperature stable and because of it's molecular size make it harder for air to leak through rubbers pores. It's all BS, nitro and air both require constant monitoring. The oxidation thing may be true, don;t know. All carson our lot in the winter have TPMS lights on, and they are filled with nitrogen. Yes, you can mix with regular air.
The 2500 will ride stiffer, but it shoudn't be too rough. Air pressure, proper greasing intervals, and updated rear cab mounts should help significantly.
25994881 MOUNT CUSHION
25791032 CUSHION
15854745 WASHER
part nunbers for mounts
