New Weight Box
95 z71
SUDDEN IMPACT
Aug 11, 2009
293
Cavan, Ontario
These are som pics of my weight box (behind bumper rule) and my pulling setup
I will post a video of my first pull with this setup from sunday when I get a copy of it.
Let me know what you think of it.
The truck pulled alot better with the front weight.
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
I reattached them.. But, I'm going to sent Rob over here to find out why the first ones are not showing:confused:
FarmDiesel22
Farmer
Sep 28, 2009
128
Do you have any pics of under the truck of what u mounted the box to?? And how did u make it? Like just solid piece of metal, melt lead into it, or ??????
95 z71
SUDDEN IMPACT
Aug 11, 2009
293
Cavan, Ontario
It is mounted into the frame where the tow hooks mount. 3x3x.250 wall tube mitre cut and welded to make the supports and welded to the base plate.. The base is 14"x36"x.5 plate with a 5"x36"x.5 back plate and 4" high sides. It is open on top.The front plate is 7"x36"x.250 plate and is bolted to the tubes.. The box empty weighs about 130 lbs. I used counter balance weights from an elevator(9.750"x9.750"x1.250") and some 2"x2" solid bar pieces to add weight for pulling. I will try to get some pictures of the empty box and the weight in it this weekend.
