Wish I had more room for quotes because that's sooo true and ....funny but true.:rofl:
That's the ticket right there just don't let it switch into 5th gear in a high tune.
I believe the PPE 225 hp tuner is the standard tuner they sell. I ran the PPE hot plus 2 eliminator along with my edge hot juice, only using the edge for gauges that I had no problems with.Your trans is going to be your next quest for sure.
Stock injectors will be just fine for now when and if down the road you add a larger turbo worry about the sticks then and go up in percentage for what your needs are at the time.
Efi live is the way to go for sure and if you still want to run the Edge just for the gauges (oh btw don't ever think that you can bump the edge up just a little to run with what you have ....bad idea) make sure you disconnect it before making any adjustment with your ppe it can rob the tune rite out of it when you suck the tune out of it and then it will be useless to try and sell,ask me how I know lol.
I would for sure do the boost valve it will let the turbo put I believe 3 more psi into the motor IIRC and its pretty cheap. Also1 more thing on the trans, everytime you limp it it gets easiesr to limp the next time, so your going to have to exercise some control on it or your going to be doing it sooner then later and don't wait till it doesn't move anymore to do the trans it will be packed with clutches and planitarys and if not all is removed it will play hell with your built trans down the road with heat and contamination.
It's the sad truth lol
Sent from my iPhone
