UPDATE: Temps when this first happened were -15C/-32C exluding the wind. Temps when i refilled tank yesterday were around -2 C.
Ok so i removed the hose going into the holding tank siphoned it out with an air venturi unit and sucked it right dry. I filled it back up with about 8-10Liters of new fluid. Hooked it back up and went for a test run(-2C), the DIC code was gone with in 1 minute of driving but came back on again in 20minutes. It now said 426km left of range for the fluid (which is way out to lunch) Brought it to dealer this morning let them know I need it asap if possible. I mentioned to them why they use such a high (-7 freezing point fluid? It sits outside all night non heated which can easily freeze from after work till morning when im up and I laughed sarcastically but politely...The reps at dealer spoke up and said all engineers all pulled off projects working on this solution as a top priority.
My guess is when or if the fluid intitially froze partly or completely it cracked or F'd a sensor in the tank which is now why it is still buggered.Unpluggin batteries doesnt reset anything on these trucks from what i figure.
Will let you all know what comes of this.
