New to the 2011 Urine tank :)
ratzy
Nov 25, 2010
Alberta Canada
Hey guys new to this place so a big hello to you all. I have a simple question on my 2011 HD3500 GMC which I have just completed my first oil change on and topped up the urea(as it was showing 800km left). Problem is my display still says to check or service exhaust fluid system. If someone can school me on reset procedure I would appreciate it in advance.
Thanks Ratzy
Akdiesel
IFS Hater
Aug 23, 2009
2,213
Fairbanks
Can't be of help but welcome to the forum. There are a few guys on here that have LML's so I know someone can chime in and help!
Dec 2, 2006
1,696
TN
I have 2000 miles on mine and I've never put DEF Fluid in yet. The light should go off if you filled up to the spec of 5.5 (I think?) gallons.
13,748
821
Here is some info from this PDF from GM.
Once the system is refilled, the system resets itself and a
service visit is not required. It may take up to 30 seconds in park or several
miles of driving to update the DEF level warning.
And this:
See your Duramax owner’s manual
supplement for a complete description of the electronic onboard warning
system and its warning messages.
Also, it's Urea, not Urine. I hope you didn't piss in the tank :rofl:
ratzy
Nov 25, 2010
Alberta Canada
Yeah ive looked in the manual and cant find it anywhere.....I am now limited to 89km/h untill somebdy can help me....the service dept at my dealer hasnt returned my calls .....nice.
Thanks but the link isnt working.
13,748
821
Sorry, I fixed the link and and the first quote in my post.
9,905
151
:mad:
That is so %$#*@^* Gay!!
WHY would they do something so dumb?
:mad:
Jared Duramax
<---- $$$ Whore!!
Feb 13, 2008
1,052
Matthews NC
if the truck is limiting you on how fast you can go it is very low on DEF the next step is for it to not start. i would check to make sure the tank is completely full.
And a little advice be very careful with DEF it will destroy aluminum, stain blacktop, and really do some damage to paint if it is left on there too long
9,905
151
I'm guessing because it's thanksgiving and they're closed. ;)
I was talking about GM in general.
And this guy could be from Canada as he has nothing in his sig to say where he's from. Our thanksgiving was 6 weeks ago.
3,733
305
Sounds like it was either the wrong Urea solution (it requires a very specific concentration, somewhere around 40-50%, I can't recall right now), or very poor Urea.
Where did you get it? Did it say "Diesel Exhaust Fluid" on the bottle? I'd try siphoning out as much as possible and refilling with good fluid, then see what happens.
Or, have the codes read first. It will probably tell you exactly what it doesn't like about the situation. That is your best bet to get back on the road.
Finally, as others have said, what is your location (Canada/US?) and please fill out your signature with info on your truck (look at what most people on here have). Good luck!
13,748
821
Since he's using kilometers, I'm guessing he is outside the US.
ratzy
Nov 25, 2010
Alberta Canada
Sorry guys I was away for the weekend, yes I am in Canada and al things are pointing to the fluid being frozen.. I just spoke to the dealer and all kinds of horror stories have been rolling in. Apparently they are working with engineers to come up with a fix pronto as maybe the heating system wasnt sufficient to heat that amount of volume, they are recomending to not fill over half unitll GM comes out with their buleting/fix. Bummer what a pita !!!:mad:
3,733
305
Let us know what happens if you siphon half out. If it starts working, that would be interesting...
What are the outside temperatures when you are having the problem? I am curious how cold it gets where you are at.
stacks04
792
Terryville,Ct
This was my biggest concern for guys in the northern tundra. 5 gallons of fluid is alot to defrost when it has frozen in -40* temps overnight. It is going to cause all sorts of issues very soon.
9,905
151
I called it 6 months ago that this would f things up for people up here........
