New Rattle Sound
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
For a few weeks now I've heard a different rattle tone in my engine. When i put the go pedal down and run the rpm's up i hear a completely different tone in the engine. Not sure how to really explain it, but that's what i hear. And also when i shut her off after just an easy drive, i hear a rattle underneath like something is broke somewhere. Not sure what i could be facing, but it don't sound good. Any thoughts or ideas? Thanks!!
arneson
Aug 14, 2011
2,133
stoughton, wisconsin
All the noises u are describing never were there before? Gettin worse? Have u put any new parts on? This is goin to sound stupid but my dads started to rattle when he shut it off and started to get worse. I chased and chased and it ended up bein the CAI loosened up and would hit the fender. It was the frame that went around the filter. Prolly not what u are hearin but an idea to check.
dmaxman06
May 25, 2011
493
morenci az
i had a exhaust hanger the 2 holerubber one that was up against the heat sheilds under the cab/bed and when the rubber wore down to the metal bushings it started rattleing like that so make sure to check that nouthing rubbing under the truck
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
Never heard the noises before. So as far as i know they are new. Thanks for the pointers on where to look for now. As far as the converter, I hope not. How much that cost to fix?
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
Stock converter yes. I did find the rattle though. A bolt came out of a hanger on the rear part of the tailpipe. But that still doesn't help me with the rattle tone difference in the motor. :(
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
Could be an injector or a whole list of other things, start by checking balance rates and if those are good then get a stethescope and start searching. Could also be in your tuning. Might try making a video of the sound and posting it.
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
I'll be changing the oil this week end, so i will see if that makes any difference of not. I'm not sure if i could get the sound to be heard through it or not. See how things go this weekend i guess. Thanks for the help so far. :thumb:
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
G thanks guys. Act like i'm a wetard or somin. Gesh!! :happy2: I put a quart of tranny fluid in for now. All i had at the time. And since then i haven't got on her to see what it sounds like.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Seems like you fixed the rattle under neath the truck now the engine rattle. I'm assuming when you shut it off rattle is gone that was the exhaust.
The engine rattle could be pilot injection. Or have you disabled it with a tune? Does it do it stock,I see you have EFI? Have you checked your balance rates? A rattle can be from a injector and as mentioned try some 2-stroke oil. See if it changes.
Good luck
Sep 10, 2008
1,072
Morehead City, North Carolina
Is 2-stroke a safe alternative to use on a regular basis? I know that adding motor oil will increase viscosity but it doesn't actually increase lubricity.....Always spend way to much $$$ on Power-Service from Advanced Auto & Walmart (which I hear is worthless anyway). Just dropped big money on brand new set of 45% overs from Exergy. Would hate to damage them.
Thanks
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
Yea exhaust rattle is gone. Broke a bolt in the one hanger. I haven't tried the stock tune, maybe i will tonight. I haven't quite had time to hook up my efi and run a scan yet. One of these days i hope to.
6,025
Thanks
ive used it for the last 80k and injectors have been at 2.0 or less. i use one quart of it per fill up.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Whole quart you say I thought I was nuts at a half a quart and I have a bigger tank but I fill up between a half and a quarter to l put less strain on the wallet.
