Dan, I like the raw aluminum finish and the black blends in a bit better and have been considering the "yellow one" for quite some and had no idea about the oil pressure increase on yours which makes it an attractive alternative.
Did not find the install PDF sheets on your site.
Does it come with bolts.?
Does it come with a tube a ACDelco pan sealant or equivalent.?
Yes bolts are included, sealant is NOT included due to shelf life.
Sorry if this is a dumb question, but what is the benefit for higher oil pressure?
As the oil gets hot it thins out, thus lowering oil pressure (you will see this on your gauges when the engine/oil is cold vs hot). The pan helps these issues by UN-shrouding the pickup (less inlet restrictions) and keeping the oil cooler, along with 2 extra quarts of oil (vs our competitor).
Engine oil pressure is VERY important, as it will keep metal parts isolated from each other.
More importantly, how's the ground clearance
Can you post a bunch of photos of one installed on a truck? Thanks.
Not an issue!! Not only is there plenty of clearance, but our drain plug is in the back of the pan (not the bottom, like our competitor). So no worries about it getting damaged or broken while off-roading
Subd for pics of one installed
See pics!
